Wide bar/ narrow bar
bud barenie
07-07-2002 07:18:42
went to my first pull yesterday! totally restored super m ! got my but wooped! couldn't get a bite
using 13-38 bf silvertown tires!! bars are very uneven warn !!! changing to 14.9-38 goodyear
groun grip, my question is ? how important is bar thickness, new tires have skinner bars. about an 1.25" CLOSE TO CENTER! BUT THEY ARE OLD AND DEEP IN TREAD. NEED HELP !!! GOT A BIG MOTOR AND A BEAUTIFUL TRACTOR. SHE DESERVES BETTER!!
ken
07-08-2002 20:03:36
 Re: wide bar/ narrow bar in reply to bud barenie, 07-07-2002 07:18:42
What pull did you go to.I think the angle of the bars are most important. The 23 degree angle tires work real good.The 45 degree tend to slip more.If you have that big of a motor you might want to go with cut tires.The slick tires with cut angles are the best but you can't run farm stock.Also 16.9 or 18.4 tires will do that much better if you got the power. The more rubber on the ground the better.
BUD BARENIE
07-10-2002 05:11:52
 Re: Re: wide bar/ narrow bar in reply to ken, 07-08-2002 20:03:36
KEN. THANK'S FOR THE REPLY! WENT TO BREMEN INDIANA
FARM FIELD 5500-6500LB CLASS AND 6500-7500LB
3MPH 1ST GEAR PULL !!! MOTOR HAS BEEN REBUILT A FEW MODS, RUNNING ABOUT 68HP ON DYNO !!! JUST A NICE STOCK TRACTOR !! THANK YOU !!!
