What parts for an M
BD
07-31-2002 10:36:24
I have a stock farmall M and was wanting to know what were the best parts to make a 100+hp puller. What is the biggest size piston you can put in an M? Who makes the best pistons for the most hp? Will a 450 carb bolt on to an M?, and how do they compare to one from Dennys? Who makes the best intake/exhaust systems? Who has stroker kits and how do they compare?
Any help appreciated, BD
randy
08-01-2002 08:10:19
 Re: What parts for an M in reply to BD, 07-31-2002 10:36:24
Dont go to dennys he has overpriced junk! I bought a stroker kit off of denny he said with his carb and distributor it would give me 120hp. well boy was he wrong it put me at about 91hp. i paid $ 3,500 and only gained 28hp what a rip. stay away from denny what ever you do.
redhead
07-31-2002 18:14:53
BD, Denny's is okay, but there are other builders that should be considered too. Pick up an issue of The Hook, there are several builders in there that should be looked at too. If you want to pull in a stock class, be careful, too much hp/torque on uncut tires isn't a pretty sight. Most 248 cid blocks will bore to 4.250 with sleeves, after that there's a 50/50 chance you'll hit water. A 450 cam/head/manifold and an 806 carb are good choices. Also, spent some time/money to make the head/manifold flow well. Borrow or rent a dyno and track your progress as you go. Good Luck.
M puller
07-31-2002 12:47:48
Dennys has a stroker kit that makes 350 cubic
inches I know an M that has it in it and he can
ride his brakes all the way down th track. Hope it
helps
JLF
08-01-2002 10:58:44
 Re: Re: What parts for an M in reply to M puller, 07-31-2002 12:47:48
IF YOU GOT THE MONEY TALK TO PAUL OR GREG AT LEMMONS TRACTOR RUSHVILLE IN .THEY MAKE THE MOST HP.
bjuck
08-01-2002 20:20:23
 Re: Re: Re: What parts for an M in reply to JLF, 08-01-2002 10:58:44
my buddys dad put a turbow on his M and messed with the carb. and hes got about 85 or 90hp but they don't allow him to pull
