Where do I start losing weight on an Oliver?
Allis Puller
08-01-2002 16:40:37
Building an Oliver 88 puller and would like to get her down to 4500#. I've Already got pressed steel rims and I only weigh bout 160 lbs. So what else do I need to strip?
casey
08-04-2002 18:56:58
 Re: Where do I start losing weight on an Oliver? in reply to Allis Puller, 08-01-2002 16:40:37
i would feed her a lot of subway meals like the commerical on tv.
A.P.
08-02-2002 02:19:45
Nothing, you should already weight less than 4500 unless you have a wide front and a loader on it. Seriuosly with pressed rims on the front and back along with a narrow front will get you down below 4500. Remove the hydraulic unit, belt pulley and PTO and you will be in the 4000 class.
Good luck,
A.P.
Agent Orange
08-01-2002 18:09:56
You could trade it for a WD
Allis Puller
08-03-2002 12:15:07
 Re: Re: Where do I start losing weight on an Oliver? in reply to Agent Orange, 08-01-2002 18:09:56
You aint tellin me nothin, didn't you see my name "ALLIS PULLER" I've already got a "WD" that I pull with and it does real well. Now I'm lookin to go with a bigger tractor. If I wanted to know what is a good tractor for 4500# your post would actually mean something!
Agent Orange
08-05-2002 18:27:46
 Re: Re: Re: Where do I start losing weight on an Oliver? in reply to Allis Puller, 08-03-2002 12:15:07
Maybe I should have said WD45 Lots of them around here pull 4700 / 5200 and do very well.
Bob
08-01-2002 21:23:24
Heck, i would imagine likely you could get three or four of them WG tractors for a good oliver WOW that might not be a bad idea.
george
08-01-2002 17:23:27
I would remove the belt pulley assembly and the power take off if your local rules permit. That should allow u to have some moveable wt.,as well. Other things can be done but that is all that would be necessary.
