What should i do first
1944-A aron
08-05-2002 21:23:22
I have a basically stock 1944 JD A. There is a local pull near here (45 min east of Charlotte, NC) in a month and a half or so. Dont want to spend BIG $$$ right now, but what would you do to this tractor for a pull? Or would you just go and watch... again?
Gary
08-12-2002 14:25:04
 Re: what should i do first in reply to 1944-A aron, 08-05-2002 21:23:22
your tractor has a fast first gear if you have stock tires (13.6-38) pull the tractor as light as you can. I have seen these tractors pull stock and they dont have enough power.1950 and up have a slow first gear and they dont chock in first gear.
G Taylor
08-08-2002 19:55:52
Read G-Man's post above in answer tothe fellow with the B and wants to win. As long as she doesn't stall in 1st gear worry about getting the rear tires to bite, max the hitch height and get the weight balanced.
DANNY HOGGE
08-07-2002 19:44:16
CALL RICK OR RONNIE FUNDERBURK . THESE 2 HAVE PULLED A J.D. " A " FOR MANY YEARS " OLD CHOKIE ". THEY PULLED 4700AND 5200 WEIGHT CLASSES AND WON THIER SHARE.I THINK THEY LIVE IN LANCASTER OR ROCK HILL S.C. GOOD LUCK. DR SR
SteveV
08-07-2002 19:02:16
You need to hook on the sled and see if the issue is HP or traction...or maybe both. After you pull let us know which problem needs solving.
Steve
Richard
08-06-2002 08:58:18
If you are referring to the pull in Oakboro- It will be stock RPM's, 1st gear, no cut tires, and I would recommend wheelie bars or you will get red flagged if the front tires comes up more than 12 inches. You should be able to pull in the 5200 and 5700lb class. LOL
sandlapper
08-06-2002 16:16:21
 Re: Re: what should i do first in reply to Richard, 08-06-2002 08:58:18
Bring the A down to Pageland this weekend.Get your feet wet, and I am sure you will will get some hints and suggestions from other pullers, a really good bunch of guys.
curt
08-06-2002 06:10:27
find out the rules first there are so many different classes and rules that you need to know what kind of pull you are going to ie. barnyard stock, stock, modified, cut tires etc. then decide if you need to do anything at all to your tractor. after you find out the rules you can ask more specific questions..... .good luck
Agent Orange
08-08-2002 18:00:06
 Re: Re: what should i do first in reply to curt, 08-06-2002 06:10:27
That's good advice! Pageland would be one starting place. Statesville (Tomlin Mills) off I77 is another (1st weekend of the month usually). North Brook up past Cherryville mid month is another. You have plenty of opportunities and it is all for the fun and a few bragging rights. You'll meet some very "interseting folks" along the way. GOOD LUCK
Matt B
08-06-2002 05:55:17
Just jump in feet first! I watched for a year or so before I began pulling, but I didn't learn as much in that year of watching as I did after my frist pull. As long as your tractor is running good just find a way to attach weights. You shouldn't need much more than 100# or so on the front, if any, so put most of the weight on the back.
Good luck
Matt
