What size tire
Andy
08-20-2002 10:54:39
I am wondering what size tire would work best for stock pulls on a variety of tracks. The tractor is a MM U standard. It would most likely be pulled 6000 lb -7500lb class. It has 30" rims but we could put 34" on it. We were thinking used 18.4 X 30's or 16.9 X 34's Thanks
G Taylor
08-20-2002 15:40:23
 Re: What size tire in reply to Andy, 08-20-2002 10:54:39
If limited in contact area but have the option of several tire sizes, go with the largest legal dia rim and narrower on the tread to meet the square inches rule.
520-LP
08-20-2002 14:38:37
check the rules where you are going to pull to see what size tires and rims you are a allowed to use where we pull.in stock classes the. max. tire size is 16.9 on 14inch rims
