1949 JD B wide front worth trying to pull with ?
Jerry C
09-04-2002 21:24:19
1st tractor I've owned, totally stock, Tires are weather cracked, and small chunks out of sidewall. Runs excellent, looks like pulling would be fun. Live in northeast Okla, looking for info for local pulls Thanks Jerry C
phil
09-06-2002 10:24:38
 Re: 1949 JD B wide front worth trying to pull with ? in reply to Jerry C, 09-04-2002 21:24:19
The late model B's do a good job. They have an extra low first gear (1.5 mph) so they never run out of power. Raise the drawbar to 20", lower the rear tires to about 9 or 10 psi, and have fun.
Jerry C
09-10-2002 18:12:37
 Re: Re: 1949 JD B wide front worth trying to pull with ? in reply to phil, 09-06-2002 10:24:38
thanks for the info about hitch height, I need to go find a pull and see how they set-up Jerry C
