Re: Re: Re: Re: Re: jerrys g head
lynn
09-05-2002 17:15:59
G Taylor..i don't think it would do anything but help..to what extent i would like to try one and find out..i always set the timing on the dyno at around 500 rpm on the pto so it should be optimized there..with the higher compression tractors i retard the governor one tooth so i can retard the timing..the mag won't retard enough to get maximum hp unless i do this..figure there is 18 to 20 btdc..need to check with a light but just haven't..lynn
