How much power can an oliver 88 make
235
10-05-2002 14:50:37
I bought an oliver 88 gas and was wanting to make a pure puller out of it. What is the max bore and stroke you can make out of it. Who makes kits for it? Thanks
235
bigmotors
10-08-2002 04:13:06
 Re: How much power can an oliver 88 make in reply to 235, 10-05-2002 14:50:37
Uncle Lawrence G. in Ohio
I don't know if Duke does 88's anymore or not?
Duke did Tilleys, Bears, and Coxs. They all did there own stuff later on to them.
I would stay with a 4 3/8 bore, with a good size crank. After 5 5/8 you have to start doing alot of grinding. With a 88 block - 4 9/16 by 6 1/4 is about the limit. If you can run some rpm's, I wouldn't go crazy on the cu. I would try to do it yourself, unless you got a big pocket book, and really want that $10.00 dollar trophy.
Check your rules first.
CALL TILLEY, HE HAD THE BADDEST 88 AROUND!!!!
10-07-2002 17:12:38
call greg tilley in north carolina. he had one of the baddest 88 in the country. he sold it to a man in tenn. i was told it has'nt been beat all summer, even at those outlaw pulls.
TimC
10-07-2002 20:16:15
 Re: Re: How much power can an oliver 88 make in reply to CALL TILLEY, HE HAD THE BADDEST 88 AROUND!!!!, 10-07-2002 17:12:38
Got beat a few weeks ago. Loose track and wouldn't hook. Driver error. Cody Agent got him by a few feet with an Oliver/????? turning 7 thousand rpm. But he made up for it at the state fair.
235
10-06-2002 13:59:19
Can you put super 88 or 880 parts on it?
A Man
10-06-2002 06:41:01
go ahead and drop a bunch cash and my $500 A JD will still beat a oliver the name of the game is getting what HP your have to the track I have seen tractors spin out with 200 hp and 34hp win the class because he did not. that is my 2 cents
TimC
10-07-2002 09:24:34
 Re: Re: How much power can an oliver 88 make in reply to A Man, 10-06-2002 06:41:01
I have never seen an A pull 5th gear at 15 mph.
In other pulls, wheel speed is the name of the game. Thats why there are differant kinds of pulls.
A lot of people just don't like 1st gear. Thats why they start with your kind of pulling and end up with Winston Cup Drag racing.
big oliver
10-06-2002 08:56:51
A-man your so full of it whenever you open your mouth sh!t rolls out of it. There is no way in hee! that a 34 hp junk 2 banger is gonna beat a 200 hp oliver. I think someone is just mad cause 2 bangers cant run with the big olivers.
A Man
10-06-2002 19:56:54
 Re: Re: Re: How much power can an oliver 88 make in reply to big oliver, 10-06-2002 08:56:51
That is what the last ollie said and last I saw of him I won the class and he still crying over spilt milk he spun out and I did not but the track can make a big differance but I just do it to have fun and that is name of the game. my tractor is a plow tractor and i run it all day and on weekends when I can I take it to pull and I only gave $500 for it and It dose win not all the time but sometime. and It nice when I stomp an whimpie ollie
What can I do for 2000$-5000$?
10-05-2002 22:31:47
big oliver
10-05-2002 20:39:29
You can get about 620 cid out of it and a good engine will run you anywhere from 25,000 to 35,000. about a 4.5 bore by 6.5 stroke.
There are 88 oli's making 200hp? that's funny
10-06-2002 13:21:27
 Re: Re: How much power can an oliver 88 make in reply to big oliver, 10-05-2002 20:39:29
They Actually Make More Than 200
10-06-2002 19:36:49
 Re: Re: Re: How much power can an oliver 88 make in reply to There are 88 oli's making 200hp? that's funny, 10-06-2002 13:21:27
And it can be done WITHOUT breaking or bending the NATPA rules.
Paul
10-05-2002 18:39:33
about 600 cubic inches .about 200 horse power( dependig on rules turbo? rpm?) i,m talking naturally aspirated at 30% over and $20,000 for the engine plus probably $10,000 for tires transmission rearend gears and modifactions.no those are not canadian prices . But a lot can be done to have fun for on abudget.pulling in div. 1 and div.2 is more about tires and balance than engines . ask a guy that has a jd ( or other model)with a creaper gear
