WD Engine Upgrade
Bruce
10-26-2002 21:52:36
I've got a WD45 with a WD engine and want to upgrade to the 55 - 60 hp range similar to the Allis 175 for use as a puller (low gear only required where we pull) and for mowing grass, ie misc utility work.
What are the better piston options? Who makes a good piston and sleeve kit which ups the compression and power but will not require high octane fuel?
What should I do with the camshaft?
It currently has a magneto ignition. What is one of the better ignition setups?
Any help is appreciated. Thanks in advance.
mark
10-27-2002 04:40:38
 Re: WD Engine Upgrade in reply to Bruce, 10-26-2002 21:52:36
that tractor with in low gear will have more hp stock than you will need, any more and you will just spin out and spend a lot of money for nothing.
Allis Puller
10-27-2002 10:29:42
 Re: Re: WD Engine Upgrade in reply to mark, 10-27-2002 04:40:38
What Mark said is very true except that if you gonna be pulling up into the heavy weight classes that extra h.p. will come in handy. I used the 175 Allis piston, and those you have to get from an Agco dealer. They do have the aftermaket pistons, like Tisco's but they are'nt the same, a true 175 piston is 1/4" taller than original giving you about 180-190 lbs. of compression. Also I would'nt recommend having a cam done, I myself don't do any brushhogging with mine but I don't think it would hold up. Oh and one more thing a 4 1/2" crank will be needed. That combo should get you plenty. I myself if your just pulling 1st gear would get a set of 14" rims and 14.9 firestones and I will promise you you'll be a contender. If you have any other questions email me. Kurt
ac
10-26-2002 22:23:34
try to find a gleaner e combine and use that motor
