Ford 8000
Jordan
06-07-2001 05:03:26
Has anyone ever seen or pulled a Ford 8000? I would like advice on weights, classes, and setup. I have 18.4-36 rears with fluid, fronts with fluid, and a cab. Other than that there are no weights. I want to keep it stock as we still farm with it too.
Thanks, Jordan.
Joshua Custer
04-20-2004 09:55:26
 Re: Ford 8000 in reply to Jordan, 06-07-2001 05:03:26
i have never pulled a 8000, or seen in that matter but i do pull a 5000 (hot stock). the weight positioing depends a lot on the track and the grippig of your tires. i can talk to a few people and see if i cant find a little more info. i have always drained the fluid but if the tractor pulls better heavy leave it. where are you from? i pull in western MD. i am planning on pulling more after i get out of school. well il get back to you. Custer.
C Robbins
05-07-2004 15:06:11
 Re: Re: Ford 8000 in reply to Joshua Custer, 04-20-2004 09:55:26
I am a all Ford farmer, I would like to get in the hot farm stock class in the next few years, I have a 6600 Ford with pump turned up and larger injector tips. What would be the class I could pull in?
