1944 Model B weight
Wayne Johnson
12-06-2002 14:45:47
I just restored my 44 B. I would like to pull it and wanted to know about what it might weight. The tires are loaded, is that good or bad? Thanks for any help, Wayne
Will P
12-06-2002 20:08:53
 Re: 1944 Model B weight in reply to Wayne Johnson, 12-06-2002 14:45:47
My stock 43B with cast centers, hand start, no fluid in tires, with the war cast iron frame, you would have the cast frame too. Weight is 3800 lbs.
Will P
Keddano
12-06-2002 20:25:12
 Re: Re: 1944 Model B weight in reply to Will P, 12-06-2002 20:08:53
My '46 "B" has electric start,cast rear,powr-trol,fenders...it's about 4350# If you are thinking of pulling your "B" get rid of the loaded tires,Powr-trol(if you don't need it) and get steel press rear rims. The stock "B" is too low in the power department to compete at the heavier weights.
