WC chasing its tail
Andy
12-14-2002 06:09:53
I have been trying to find a set of pistons for my WC puller 4 1/8" that are taller than stock. I have WD45 in now with 2.371 height looking to increse that. I have checked with agco about 175's but only 4" no 4 1/8. I was told use WC/WD but they are either not available or cross ref to the same height. I checked about having some custom made, I dont make that much money in a hole year! There has to be a source out there somewhere because I have had a lot of advice, but getting some wrong info from someone, A lot of sources dont have any dia. data on hand so there no help, so it is like Im chasing my tail and am dissy right now thank for any help. Andy
George G.
12-16-2002 11:20:43
 Re: WC chasing its tail in reply to Andy, 12-14-2002 06:09:53
Sealed Power has piston's with a comp. dist. of 2.7187",p/n 1728P or whole sleeve assy. p/n SL-1728. For the G201 engine,can't be used if you have the WD-45 crankshaft. And they can't be used in the WD-45 engine
agcopuller
12-16-2002 06:28:50
I here you Andy, it seems the aftermarket such as Perfect Circle, Federal-Mogul, Tisco, and some imports all offer 4-1/8 pistons but the compression height their offered in makes them essentially useless except for someone who wants to run distallate fuel. The best of the above forementioned companies offers a 2.3906 compression height, while a stock 170 gas used 2.600 and the 175 gas used 2.6250 for 8.0 and 8.2 compression heights respectively. I personally won't use flat tops, you really can't with the flat head i.e. no combustion chamber, however these will probably make more power than the above mentioned lower compression. Irv is right, Ross pistons will make these with the dish to create the combustion chamber but why stop at 4-1/8" This is the same price they quoted me on 4-1/4", and if we all got together and ordered lets say a hundred sets the price would get much better say $300-$350 and these are made of the same material as NHRA, Winston Cup, 8000rpm plus motors require. Please email me if anyone has some interest.
john
12-16-2002 06:05:37
What you want is 1/8" over pistons for a WC, not a WD45 D-17 170 etc. It is true that the late model Allis engines had higher compression than the older WC, but the newer engines used a 4.5" stroke not a 4" like the WC. Savy??
KBMO
12-16-2002 05:56:37
What you are looking for is a set of M&W pistons for the AC. They don't make them any more though :) I have a used set in good shape I would sell..... kbrownfi@isgcolumbia.com
Irv
12-15-2002 13:32:35
rosspistons.com They have flat and dished pistons
for AC engines. About $440 for a set of 4.
knowledge
12-14-2002 07:07:17
combine wd45 crank with wc/wd 4 1/8 flat top pistons.this will give what you want combined with the wd45 manifold &carb.and d17 goveror spring.
Allis Puller
12-15-2002 08:16:20
 Re: Re: WC chasing its tail in reply to knowledge, 12-14-2002 07:07:17
Heres some knowledge for you "knowledge" - They don't make 4 1/8" Flat top pistons. Tisco or Temco's pistons, yah sure they are 1/8 bigger but if you look at the part #'s for WD,WD45,D17,And 175 they are all the same a powercrator piston of stock WD45 height. So what you could do is have someone weld an Aluminum ad on to the top of a piston to get you the compression you want.
Tractor Rod
12-15-2002 13:04:43
 Re: Re: Re: WC chasing its tail in reply to Allis Puller, 12-15-2002 08:16:20
Hey allis puller I just put in a set of 4 1/8 flat top for my WC. As far as I can remember Tisco had 4 1/8 crater or flat top. Tractor Rod
Allis Puller
12-15-2002 14:27:55
 Re: Re: Re: Re: WC chasing its tail in reply to Tractor Rod, 12-15-2002 13:04:43
Hey I'd like to know where you got them? But Tisco does'nt make Flat top I looked them up. My Dad is a dealer.
knowledge
12-16-2002 16:51:39
 Re: Re: Re: Re: Re: WC chasing its tail in reply to Allis Puller, 12-15-2002 14:27:55
all of the piston kits for wc/wd are flat top that you can buy from all parts books i have seen.i did find a set of old high attitude power crates pistons for wc/wd or 4inch stroke.that is working very good with 4.5 inch stroke and is giveing me 270PSI.runs like a bear.I am thinking of selling this engine to open class.if anybody is looking for a great div II pulling motor.
