OVER SIZE VALVES FOR JD-B CYLINDER HEAD??
2 cylinder
12-15-2002 19:00:47
Building a 42 John Deere-B for pulling, and want to use oversize valves. Can I use JD-A valves? Suggestions welcome. Thanks!
kenny graves
12-16-2002 16:38:59
 Re: OVER SIZE VALVES FOR JD-B CYLINDER HEAD?? in reply to 2 cylinder, 12-15-2002 19:00:47
I have 44 B that i used unstyled A valves,runs good.It also has two inches on the crank.This setup puts it at about 50 hp.It is pretty tough in 3500.
2 cylinder
12-16-2002 21:12:26
 Re: Re: OVER SIZE VALVES FOR JD-B CYLINDER HEAD?? in reply to kenny graves, 12-16-2002 16:38:59
What are you running for bore size? And what kind of cylinder head are you using? Thanks.
KENNY GRAVES
12-17-2002 09:57:52
 Re: Re: Re: OVER SIZE VALVES FOR JD-B CYLINDER HEAD?? in reply to 2 cylinder, 12-16-2002 21:12:26
The bore is 4 11/16 and i have the stock cyclone head thats been ported and polished.The rods were made at Schoolers and I got my pistons from him.If need more info email me.I Pull the B and also a G and my brother pulls a G.
