Case LA engine rebuild. Need HELP please
Texas Red
12-23-2002 02:50:52
It is almost time to start puting the LA back together. I have located the index marks on the cam and crank, Is there a mark on the mag-gov gear also or is there another way to time the mag?? This is also a propane block and head we are rebuilding. we are going to put the crank, sleeves and pistons out of the gas engine that was froze and busted into the propane block. It will be put on gas so does the time have to be changed any??also the propane pistons are in good shape, what would be the best combo to go back with?? We are going to put the propane Cam and lifters back in it. We have a lot of good parts to pick from. Thanks for any and all help. TR
