What should I do to make my 460 diesel a puller?
Big red 460 die
12-30-2002 18:46:41
I want to know what I should do to make my 460 diesel a good pulling tractor. As in going in the engine or transmission. Also trying to get the most power out of it to. I already have had the injectors re-done and the pump re-done and tuned up so the engine has plenty of fuel. What should I do? Thanx for the info.
Jrred
12-31-2002 05:34:57
 Re: What should I do to make my 460 diesel a puller? in reply to Big red 460 diesel, 12-30-2002 18:46:41
Big Red If you realy want a screamer put some lp gas to it make sure you use a regulater an ajustable on works nice plum it in at the center of your intake use a nozzle like from an either injecter you can run at 30% lp and be safe I have seen them run more but you realy start to loose a lot of lubercation that is needed!
Donnie
12-30-2002 19:43:15
Go get a 282 Diesel out of a 560,660,0r 706 and put in it. They are a bigger stroke. Take the oil bath air cleaner off and use a dry element type off of a 706. Done this and it was worth about 20 extra horse. The 560 deisel (282) will turn 100 to 120hp's with out a blower.
Farmall Boy
12-30-2002 19:31:06
Make sure it can get plenty enough air and plenty enough TRACTION wich is the main thing if u have the power
Farmall Daddy
12-31-2002 07:15:23
 Re: Re: What should I do to make my 460 diesel a puller? in reply to Farmall Boy, 12-30-2002 19:31:06
I would oversize the pistons in it. If you have the money, you can bore it but that costs a big chunk of change. It depends on what class you want to run it in like the 6500-7500, if that is how much it weighs, or if you want to get right up there with the big boys. For the lighter weights, I wouldn't do anything to the motor, the torque amplifier should keep the power balanced if you would need it in 1st gear. For the classes 8500 and up, you may have to oversize the motor or bore it, your choice.
