Re: I need some pulling tips.......
Farmall Daddy
01-08-2003 16:34:19
I have been to a lot of pulls and the two things that I see the most are 1. Guys don't know when to pull the torque. When your motor is bogging down and you tires are not slipping to bad, pull it back. Don't let the motor almost die before you yank it because if you do it will spead the motor up too much, and you tires may spin out. 2. Don't let your front end rise way up in the air. Some guys really think that doing this gets them to pull further. Wrong, it lowers your drawbar, and prevents the maximum downpull onto the tires. Let the front end sort of float or weight it down. If it floats, you put your entire tractor weight on the back tires without the loss of drawbar height. Doing these to things will help you pull a far as you can.
