Compression ratio
baystatebinder
02-03-2003 07:48:35
If you have a motor with a compression ratio of 16.5-1. I want to put a compression tester on the motor how do I trasfer the pounds of compression into compression ratio?
Stephen
G Taylor
02-03-2003 17:35:53
 Re: compression ratio in reply to baystatebinder, 02-03-2003 07:48:35
Depends on cam timing/volumetric efficiency at cranking rpm. Cranking rpm also affects pressure as the univeral gas law heats the air more/raises pressre the faster the air is compressed. Also less time for air to leak past rings/valves at higher rpms.
phil
02-03-2003 09:19:09
This equation will get you a fairly good estimate: Pressure = 14.7 X R^1.24 - 14.7 For a 16.5 ratio, 16.5 raised to the 1.24 power = 32.34. Multiplying by 14.7 gets 475. Subtract 14.7 to get the answer, 461 psi.
Rusty
02-03-2003 08:03:57
You can't. If you have 16.5-1 ratio, then you already know what the ratio is. I assume this is on a diesel engine? You should have around 4-500 psi on a compression test. Dont really know what you are looking for. Good Luck
Rusty
baystatebinder
02-03-2003 08:09:47
 Re: Re: compression ratio in reply to Rusty, 02-03-2003 08:03:57
I am looking top find out if I have enough compression. I was also looking to see if there was some kind of formula so it could be used on other tractors when you know the ratio. The tractor I am working on is a Cockshutt 570 s.
Thanks
Jim
02-04-2003 16:45:01
 Re: Re: Re: compression ratio in reply to baystatebinder, 02-03-2003 08:09:47
Your not Dr.Phil by chance
Jerry
02-05-2003 18:22:24
 Re: Re: Re: Re: compression ratio in reply to Jim , 02-04-2003 16:45:01
Unless you know the volume of the head cavities,Bore and stroke you can only estimate the ratio
