G Man - The Ideal Gas Law will be a little better than pure guesswork ;-) However, to use the Ideal Gas Law, you will have to dust off your Algebra and either take some measurements or make some educated guesses(like T2: temperature after compression). Keyword here is "educated" meaning that you ought to have SOME idea of cylinder temperatures after compression! If not, don't worry! The "corresponding compression ratio" result variation that you get by guessing (oh, say 680 Rankine) will not vary your results that widely: 0.1 to 0.2 "points" of compression. Just remember to use Absolute units of measure:Temperature (degrees Rankine) and Pressure (PSIA; add 14.695 to "gauge" readings) You and G Taylor are absolutely right that no equation will predict what you are going to get for a compression ratio (using cranking(?) pressure). The Ideal Gas Law will be able to "estimate" within .3 to .5 points, though! But my questions is: What use is this information? I find that the actual cylinder pressure is FAR more important than the comp. ratio! The cylinder pressure is the "proof in the pudding!" Regards, Goldsburg goldsburg@att.net
