4cyl mag on deere
john
03-21-2003 06:15:34
Since a Deere fires every time the piston is at tdc, couldn't you use a 4cylinder mag, firing only when needed. I know the l.p. models only fire once,but I am just kicking around ideas..... ..you know bench pulling.
Earl S.
03-24-2003 19:13:14
 Re: 4cyl mag on deere in reply to john, 03-21-2003 06:15:34
Yes you can use a 4cyl mag with gear driven rotor. Use any 2 side by side and ground the other 2 terminal to each other. Earl
