Which Head
BUDD
03-22-2003 14:05:07
I need some help; I have a 49 JD “A” # 634700. What is the different between the head # A2325R and A3367R, A4226R. My parts book says that A2325R is for 488000 to 583999 and A3367R, A4226R is for 58400 and up (which is for mine) I have the A2325R and I am going to shave it down for more compression. Will this head give me as much performance as the one for the late styled (A3367R, A4226R)? I can get the proper head if it will give more HP or me better breathing. Thanks for any and all comments.
BUDD
Mike in Mo
03-23-2003 08:46:31
 Re: Which Head in reply to BUDD, 03-22-2003 14:05:07
Use the late head if you can, It will have approx 6 cu in less volume in the combustion chamber, so will raise your compression significantly without milling. Air flow should be about the same in all 3 heads. Your best bet is to use a late head, mill it down, and late A/60 M&W (or similar) aluminum pistons (you'll have to grind the spark plug notch in the piston down some more). This should get the comp up to 7.75 to 8:1 range. Mike
