What should I do???
BigRed460 Diese
03-24-2003 09:25:46
I am making my 1960 farmall 460 into a puller and I need to know what things I should do to make it a good puller. Note that this is gunna be my first pull so I dont want to get to crazy with money. I have already replaced all 6 injectors and put a higher volume head in the injector pump. So it gets enough fuel. I need to get the head re-worked like all new valves seats and guides. but besides that what should I do? And I also need to find out were I can get a dry filter element fo the air cleaner. Thanx in advance.
Wally G.
03-28-2003 15:34:01
 Re: What should I do??? in reply to BigRed460 Diesel, 03-24-2003 09:25:46
I'd look in to a 560 or 706 motor and put that in. That way your up to 282 ci. Or you could get a gas 460 and find a 301 out of a 806 or 826 or 856.
BigRed460 Diesel
03-24-2003 09:49:27
I also wanted to know what shjould the compression be for this engine? Thanx and happy pulling!
Brian
03-26-2003 10:06:26
 Re: Re: What should I do??? in reply to BigRed460 Diesel, 03-24-2003 09:49:27
Whatever the rules will allow. Port and Polish the head, add a turbo (even a stock one off an old 1066 or something), and make sure your injector lines will carry the fuel from the pump to the injectors. It's all about fuel and air.
