Re: Re: M farmall boring
Pete1468
05-15-2003 15:02:16
I ran a .030 over 454 chevy piston in an M block for 3 years with a stock head gasket and no filler in the sleeve ring. I did make sure that my block was straight and my head also. It had 450 ci and 7-3/4 stroke. Never had any head gasket problems.
Mfarmallpuller
05-15-2003 19:27:26
 Re: Re: Re: M farmall boring in reply to Pete1468, 05-15-2003 15:02:16
what did you do about the wrist pin in the 454 piston it is much smaller than the m 1.312, I think 454 is .9 something
Pete1468
05-16-2003 05:42:47
 Re: Re: Re: Re: M farmall boring in reply to Mfarmallpuller, 05-15-2003 19:27:26
I had a custom set of rods that matched the piston. The motor looked bone stock from the outside.
Mfarmallpuller
05-16-2003 10:18:49
 Re: Re: Re: Re: Re: M farmall boring in reply to Pete1468, 05-16-2003 05:42:47
Wouldn't it have been cheaper to find pistons that would have fit the connecting rod you already had. If you can bore it to 4 3/8 I know the perfect piston the wrist pin is the exact size of the H rod.
Pete1468
05-16-2003 10:31:23
 Re: Re: Re: Re: Re: Re: M farmall boring in reply to Mfarmallpuller , 05-16-2003 10:18:49
Yeah, that would have worked good but I need some cam clearance room and longer rods than an H rod so I had a set made when I had the crankshaft made. Used a small block chevy rod bearing so everything worked alot easier.
DANNY HOGGE
05-16-2003 12:47:02
 Re: Re: Re: Re: Re: Re: Re: M farmall boring in reply to Pete1468, 05-16-2003 10:31:23
IF I MAY ASK. WHERE DID YOU GET THE CRANK AND RODS MADE AND WHICH CHEVY PARTS DID YOU USE . PLS ADVISE. TX, DR SR
