What are 6 powerblock pistons going to cost me?
AC
05-31-2003 08:16:37
I just said it. I found a block, but I am afraid to buy it because it has no sleeves or pistons. Does anyone know what this may end up costing me? thanks, AC Oh yeah, poll here: What kind of HP should a late A with a powerblock, stock stroke, big nut carb, and a johnson cold manifold make?
2 cylinder
06-02-2003 21:31:36
 Re: What are 6 powerblock pistons going to cost me in reply to AC, 05-31-2003 08:16:37
I have a 47 JD-A with powerblock Hinnrich aluminum high compression pistons .125 over ($450 about 4 years ago) head shaved .120 intake and head ported and baffle removed from cold manifold, and oil bath removed. It dyno's at 55hp.
Eric
06-02-2003 05:52:08
Piston will run you 700 plus from Hinrich and you will probably be put on a waiting list.
520-LP
06-01-2003 18:54:40
I have a 49A with a #2 power block, a heisler head and manifold, a G carb and electronic igintion it has 60 hp
just what u said should h
06-01-2003 12:43:43
50hp
06-01-2003 12:43:11
buickanddeere
05-31-2003 08:59:56
What rpm,compression,fuel,cam, valve size are you planning on?
AC
06-03-2003 08:33:31
 Re: Re: What are 6 powerblock pistons going to cos in reply to buickanddeere, 05-31-2003 08:59:56
I have no idea, I can get a decent deal on a powerblock, but I don't want to have to wrap up $1000 extra in sleeves and pistons. All I want to do is get into the 45 hp area so I can do hay with my 51 A. I know there are little tricks here and there like running 720? valves and things like that, but I have limited knowledge of that stuff because I am new to "building up" these 2 cylinders. Any hints or helps would be appreciated. That does it cost to have a port and polish job done? how about a heisler head? what do I have to do to the bottom end of my engine if I want to really make her crank? thanks...AC
buickanddeere
06-03-2003 20:11:49
 Re: Re: Re: What are 6 powerblock pistons going to in reply to AC, 06-03-2003 08:33:31
A set or 60 high altitude or LP pistons, oversize intake valves, blend the maching/casting smooth in the valve bowls, a cam by Roberts Carbs, a gas manifold, K&N aircleaner. Should make equivalne to a stock 60 gas or a little better. Could just trade to a 620/630 and get live pto, live hydraulics, three point hitch, optional PS and more power stock than an extra $2500 into an "A" will get.
