300 head on H
redpuller1
06-04-2003 13:49:49
I was wondering if putting a gas 300 head on a H with overbore dome pistons would help on power?
Irv
06-05-2003 16:41:35
 Re: 300 head on H in reply to redpuller1, 06-04-2003 13:49:49
I had a Farmall H with a 350 propane head and IH
"Fire Power" pistons. It put out 38 horse at 540 PTO rpm.
Steven
06-04-2003 19:17:21
Yes it will help your power some. You should have a 300 head shaved about .125" to .175" to raise the
compression alittle more and run gas with a 100+ octane rating. This should give you around 32-35 HP.
Just the 300 head,unshaved, might get you 30 HP.
hpuller
06-05-2003 11:59:17
 Re: Re: 300 head on H in reply to Steven, 06-04-2003 19:17:21
If you plane .125 off a 300 head your head gasket might not seal up. When you plane it that far the water holes get pretty big.
SHUTT30
06-05-2003 13:25:42
 Re: Re: Re: 300 head on H in reply to hpuller, 06-05-2003 11:59:17
A fellow puller I know shaved .250 off of his H head. After breaking it in for a couple of days on the dyno he warmed her up and loaded her down to see what it had. After a few minutes she started smoking like a alky burning super stock. The head broke into the water passage but the gasket looked good. This time .250 is too far.
Steven
06-05-2003 12:54:40
I had .125" taken off my 300 head and it's held
fine with a stock H gasket for 4 years so far.
But yes the water holes got alittle bigger.
redpuller1
06-05-2003 12:47:10
Hey i was wondering how much more a 300 propane head will help i have the gas head and already have had some work done to it but have not got it on the tractor yet i don't figure i can find a 300
propane but would just like to know how much it would help if i did Thanks
