Wd in 3500
AK
06-19-2003 11:44:48
can a guy pull second gear with a wd that has a wd-45 pistons and sleeves in them does it have enough power
Bruce
06-20-2003 22:31:13
 Re: wd in 3500 in reply to AK, 06-19-2003 11:44:48
Whare i live no. Get the smallist tire you can find with no tread "ones with a lot of road ware". Have someone watch your tires and make sure thay are flexing 4 to 8 lbs of air. Make sure your hitch is as high and short as is legal. Dont use high Rs. Dont lets yout tire go faster than yout ground speed. Keep your front end down and you will do fine. Good luck Bruce
Allis Puller
06-19-2003 14:33:55
Only on a very loose track. Thereare some power tracks out there now that make my engine bark pretty good in 2nd gear.
KMC
06-19-2003 14:09:41
should have depending on what size tires u have on. If you want a lot of power let me know.Have a good motor for sale.
