Cassville pull mo.results??
piston
07-05-2003 10:00:37
ASK ????? ????? ?? KROUTHEAD????? ????? ??
Krouthead
07-05-2003 18:43:08
 Re: cassville pull mo.results?? in reply to piston, 07-05-2003 10:00:37
Well,I came back with 155.00 and piston came back with about 1/2 that much.Yes,he beat my stock, ugly tractors with uncut tires.But he cant beat Gramps(80-05)with NOTHING. I went to work on the D65 today...another pull Thurs.
To Be Continued.
You know what happens when you talk shi* Big Un.
Lots O Luck
Krout
ChadS
07-05-2003 13:23:56
Looking good on the cover on the Hook! Is that Krouthead in the article with the Duetz tractors? I have never seen older Duetz tractors before around here. My brother in law pulls a Massey 101 with a Chrysler 6 cyl. Congrats on the spread in the Hook!
Gary
07-06-2003 06:43:10
 Re: Re: cassville pull mo.results?? in reply to ChadS, 07-05-2003 13:23:56
There are several of us pullers around Bolivar that would make pulls down your way if we knew about them. How 'bout some info?
Krouthead
07-06-2003 16:49:03
 Re: Re: Re: cassville pull mo.results?? in reply to Gary, 07-06-2003 06:43:10
Ok, There is a pull Fri 11 and Sat 12 at Neosho,MO starting at 7:30 both nights.It will be located at the Ozark Saddle Club Arena,next to Newton County Fairgrounds.
Fri pulling : 4700,5500,13200 & 14000 stock antique/clssic/farm tractors.6000 open tractor
Sat pulling : 6250,8000,10000,13200 & 14000 stock antique/farm/classic.6000 open tractor.
1st $50 2nd $35 3rd $20 for each weight Open 1st $100 2nd $50
Track located 1 mile south of 60 & 71 intersection / Crowder College Entrance.
For more info call Norman Drake 417 776 3014 cell 417 825 0154
Gary
07-06-2003 17:28:49
 Re: Re: Re: Re: cassville pull mo.results?? in reply to Krouthead, 07-06-2003 16:49:03
Thanks Krouthead
Krouthead
07-07-2003 05:08:40
 Re: Re: Re: Re: Re: cassville pull mo.results?? in reply to Gary, 07-06-2003 17:28:49
There is also a pull at West Plains, Mo Thurs night at 7 at the fair grounds,take 60 to 63 South just past sale barn on West side. There are limited classes 5000,7000 and 9000...Fair Pull , so all grouped together.
Wasnt very many pullers last year, but the track was excellent, need front weight!
I along with some of my pulling buds are definately going.We usually meet before and or after for BS.
ChadS
07-06-2003 11:29:20
We have a pull in Crown Point Indiana on July 12,03. we are pulling heavy to light, sign in is at 7:00 to 8:30am pull start at 9am. We pull percentage, farm stock, 3mph, 28in from center of rear axle, 18 high. 1stgear only. Modified classes are 4mph cut tires up to 15-5-38max, 18in from center of rear axle, 20 high. 10%over rpm for all classes.
