Width of rear tires
casepuller
08-13-2001 19:13:01
Does it make a difference how far apart my rear tires are set? Is farther apart better, or closer together?
G Taylor
08-13-2001 22:55:53
 Re: width of rear tires in reply to casepuller, 08-13-2001 19:13:01
A wider tractor will get you closer to out of bounds sooner. However if caught having to brake steer there is more leverage avalable to turn & less chance of spinning out. More stress however on axles,bearings etc. We have all of ours set right out so the side wall just extends past the axle end. Less chance of damage if something gets touched with a tire rather than an axle end. More stable/safer on side hills too.
