Compression
a pulller
07-14-2003 10:02:47
I have been wondering what the differance in cranking compression and just compression in psi is? like when some people say they have 300psi, do they mean that is what is checks when it runs and is read on the tester?
TimC
07-14-2003 14:11:35
 Re: compression in reply to a pulller, 07-14-2003 10:02:47
Same thing. Should be checked with throttle wide open. Will not be the same with engine running due to inertia charging, volumetric effeciency and wave actions.
answer
07-14-2003 10:53:14
Pressure at combustion is 4x compression at the compression test for a gas burner. 5x for a diesel.
