Re: Re: MM jugs
puller
07-17-2003 06:48:05
I want to put it on a U. I won't be running a TON of compretssion, I am shooting for 220psi. I want to just find a place that can do it and have it reliable. Thanks for the advice, puller
deadeye
07-17-2003 23:34:21
 Re: Re: Re: MM jugs in reply to puller, 07-17-2003 06:48:05
Use the HD800 engine to get your jugs. That is a power unit 6 cylinder. You will have to make a custom water manifold for your engine though. You can use the 800 heads also, but I don't think I would go with the LP head. If you did, You may have well over 200 lbs. of compression. This is what I was talking about in previous post. It may pound the bottom out.---deadeye
deadeye
07-17-2003 23:45:23
 Re: Re: Re: Re: MM jugs in reply to deadeye, 07-17-2003 23:34:21
Forgot to tell you that you should be able to stroke that thing to about 7 3/4 inches using a 403c.i. crank Then take your "U" or the 403 camshaft and have an 800 grind put on it. Get yourself a big carb and go racing. Contact Matt at Motec for carb.--deadeye
a puller
07-18-2003 05:31:34
 Re: Re: Re: Re: Re: MM jugs in reply to deadeye, 07-17-2003 23:45:23
can you tell me if I can get that stroke without cuttion the sidewall out of the crankcase and using the cam in the same place? What rods do I use, have heard that the massey 44 rods work good. Do you know where to get the jugs done at that could guarantee them to hold water? What are some good 5.75 pistons? tahnks alot, a puller
