What gear best to use ?
5020Chris
07-20-2003 14:44:00
Hi there, just got myself a JD5020 here in the UK and hoping to enter in the local tractor pull in August. Question is what gears best to use and how much throttle ? The tractor is standard and is fitted with 24.5 32 rears. I will be entering the "farmers class" i.e. not to many mods and straight off the farm. Usually they have quite new JDs, Case, Fendt etc so I'm thinking I might have the oldest machine there. Just don't want to look like a fool first time out ! Thanks anyway.
Chris in UK.
johnny pop
08-10-2003 20:50:15
 Re: What gear best to use ? in reply to 5020Chris, 07-20-2003 14:44:00
I would pull the beast in third or fourth depending on the conditions. Used to pull a 5020 couple years back. Started at 18,500# and went to 22,500# and didn't do that bad. Are you going to use duals?
