Stroked crank trying to get clearence
B-puller
07-22-2003 19:31:26
Got early styled JD-B went a little over 2" have it clearing the back,top of crank case but hits hard on oil filter pressure regulator body. Just wondered the best fix knife edge the crank or try to lower filter housing ??? any one want to share their hot tips thanks for any help
Jeremy Brault
07-23-2003 17:44:50
 Re: Stroked crank trying to get clearence in reply to B-puller, 07-22-2003 19:31:26
hey, i got an A jd with a stroked crank too. have the same problem. i cut my oil filter housing off. i now use a p 81 baldwin filter. they tell me that a filter out of an h will work. i do not know. hope it helps. if any questions email me
ToddF
07-24-2003 14:22:22
 Re: Re: Stroked crank trying to get clearence in reply to Jeremy Brault, 07-23-2003 17:44:50
We have a '47 A that has a clearance problem with a 9.25" stroke. We're still trying to get it to fit. How much did you cut the regulator housing down? Thanks...ToddF
Jeremy Brault
07-25-2003 20:46:51
 Re: Re: Re: Stroked crank trying to get clearence in reply to ToddF, 07-24-2003 14:22:22
I cut my housing about 2/1/2" i believe. I also had to grind the cam to about 1/2" dia. also put 4020 connecting rod ends on. and questions email me
Jeremy
ToddF
07-28-2003 06:19:33
 Re: Re: Re: Re: Stroked crank trying to get cleare in reply to Jeremy Brault, 07-25-2003 20:46:51
Did you require 2.5" to clear the stroke or is that what made the baldwin filter fit for you?
Next Question: We never had this one running previously and I don't know if the oil pressure is set properly. If you shorten the regulator housing can you adjust the oil pressure relief setting through the top of the crank case? We have two other two cylinder JD's and I have never touched the relief settings on them, maybe it just is not an issue? I appreciate any advice...Thanks ToddF
a puller
07-24-2003 17:40:05
you might have to move the cam. are you missing the gears in the back?
puller??
07-23-2003 21:10:25
how much do you have your A stroked? We have an A with a 9" crank and it clears pretty good.
Jeremy Brault
07-25-2003 20:49:14
 Re: Re: Re: Stroked crank trying to get clearence in reply to puller??, 07-23-2003 21:10:25
I have 9. It hits the cam, but i ground it done. it also hits the filter housing.
a puller
07-26-2003 09:12:51
 Re: Re: Re: Re: Stroked crank trying to get cleare in reply to Jeremy Brault, 07-25-2003 20:49:14
what year of A do you have? a 9" crank should go in a 6 speed 2 stick styled A, like 1941-46
