NIATPA percentage pull at South Bend IN
ChadS
07-25-2003 10:38:45
NIATPA is having an antique tractor pull at the ST. Joeseph County fair in South Bend Indiana, on July 30th 2003. This will be a percentage pull, and it starts at 3pm light to heavy rotation schedule. Any questions leave me a post or Email me at hpuller@hotmail.com for more information. Thanks Chads.
H
07-26-2003 08:47:19
 Re: NIATPA percentage pull at South Bend IN in reply to ChadS, 07-25-2003 10:38:45
Chad
I know this may sound goofy, but what is a percentage pull?
I'm new to the sport and don't really know what this is.
ChadS
07-26-2003 09:26:06
 Re: Re: NIATPA percentage pull at South Bend IN in reply to H, 07-26-2003 08:47:19
Well, I will explain it just like our trackside announcer would explain it to the audience.
We do not pull distance, we have a mathmatical formula to calculate percentage. We have a digital monitor that measures how far the weight tranfer box goes up th rails, we then weigh after pulling, check weight and figure percentage. our formula is this... 83x inches pulled(how far the box went up the rails of thesled) + 3260. (weight of the box) divided by the tractor weight.. For example: a 4000 lb tractor pulls, and the box goes up the rails, and measures 100 inches. (max inches on our sled is 150 in) the formula would look like this.
83x100in+3260=11560divided by 4000lbs=289%
See what I am saying? watch this. I will use a 4500 lb tractor with the same distance. and watch what happens
83x100in+3260=11560divided by4500lbs=256.88%
They way we state this is the tractor that pull the sled the farthest is not nessisarily the winner. our classes are 3260-4500 4501-5500, 5500-6000lb 6001-6500, 6501-7000lb,7001-7500lb modified and farmstock classes. I hope this helps you! thats how its done! Great question! ChadS
Mark Nethercutt
09-27-2004 12:34:01
 Re: Re: Re: NIATPA percentage pull at South Bend I in reply to ChadS, 07-26-2003 09:26:06
Chad,
I just helped with an antique pull in Indiana. Our sled was only a basic sled with dead weights, drug on the ground. A "full pull" was 10' of distance. How would you calculate the percentage on this basic type of sled? Please respond directly to rmnethercutt@purdue.edu if you don't mind.
Thanks
Mark
H
07-27-2003 06:53:04
Thanks Chad
Do you like this as well as distance pulling?
ChadS
07-27-2003 09:52:51
 Re: Re: Re: Re: NIATPA percentage pull at South Be in reply to H, 07-27-2003 06:53:04
Yes, I do. Our sled really is not equiped to handle a distance pull all the time. that is why we pull percent. Chads
