wd allis powered out in first gear after 70 ft
Andy
07-31-2003 20:36:06
i cant believe it my wd allis with wd45 sleeves and pistons in it powered out in first gear in the 3500 pd class after 70 ft were the heck did all my power go that is not right the track was very tuff
FB
08-01-2003 09:41:20
 Re: wd allis powered out in first gear after 70 ft in reply to Andy, 07-31-2003 20:36:06
DANGGG did the far,all H's even start the sled, maybe its your timeing
TimC
08-01-2003 06:22:22
Sounds like the gov did not open the butterfly.
Ron
07-31-2003 22:18:02
Well, if ya didn't change the crank to a "45 crank", you LOWERED the compression by using the "45" pistons..... !!! I doubt you did this, so--assume it is just "Tuning", Fuel supply, maybe a set of dirty air screens in the air filter...They CAN be cleaned.....but must be removed to do it..... Remember--NO WATER in the Sediment Bowl...!! One drop, and an AC will miss.....!!
