how many rpm's will stock flywheel take??
730
08-01-2003 19:24:37
phil
08-04-2003 10:29:08
 Re: how many rpm's will stock flywheel take?? in reply to 730, 08-01-2003 19:24:37
Centrifugal acceleration equals V^2/R. If the G flywheel is spinning at 2760 RPM, the outer rim is moving a about 250 feet per second. If the radius (R) of the flywheel is about a foot, then you get 62,500 ft/sec^2, that's about 1940 G's. So if half of the flywheel weighs 100 pounds, & it's trying to break away from the other half, the centrifugal force would be about 194,000 pounds across the diameter of the flywheel. If the flywheel has a 10 sq inch cross section across the weak point (at the keyholes), the casting would need to hold 19,400 psi, & that's about what a casting could do. Imagine the crash, the loose half would fly forever & the half that stayed on the crank might tip the tractor over before it came loose.
bigmotors
08-03-2003 13:14:28
A old guy from the JD expert. farm told me a "G" flywheel will let loose at 2760 rpm.
I have now idea if it is true or not, never wanted to find out.
Good Luck!
buickanddeere
08-01-2003 20:46:09
Going from 1250 rpm to 1768 rpm doubles the centrifical force. Increase rpms with care or risk catching some flying metal.
