a cure for a cherping turbo????
730/1030
08-02-2003 19:08:11
REDMAN
08-02-2003 23:26:14
 Re: a cure for a cherping turbo???? in reply to 730/1030, 08-02-2003 19:08:11
if you are talking about the cherp that starts as the engine rpms fall i know the answer-smaller exhaust housing or lower gear,the turbo will usually cherp when rpms fall because that is when it is making the most boost,the engine slows down and can not use it all,if you put on a smaller housing it will increase the boost but the turbo will turn easier.
art
08-03-2003 07:51:28
 Re: Re: a cure for a cherping turbo???? in reply to REDMAN, 08-02-2003 23:26:14
too small an exhaust housing can create ecsesive pressure in the exhaust and over speed the turbo. This can lead to other problems and damage the charger. A manifold pressure gauge in the intake and exhaust would be a good thing. The pressure on both sides should be close to the same. Art
