help wd to FAST
Bruce
08-03-2003 10:43:57
Can anyone tell me how to gear down my wd. I want to use larger tires. Most of my competition have much larger tires than i do. Thanks Bruce
bigmotors
08-03-2003 13:05:18
 Re: help wd to FAST in reply to Bruce, 08-03-2003 10:43:57
RC rearend will slow you down or find a splitter box.
Good Luck!
bruce
08-10-2003 08:39:03
 Re: Re: help wd to FAST in reply to bigmotors, 08-03-2003 13:05:18
Thay stopped RC prodution in 41 and started wd proudution in 48 will those parts interchange.
Bruce
08-08-2003 22:00:56
will rc parts fit in a 51 wd.
EarlS.
08-03-2003 12:35:28
Check on the Allis forum. I think they use a different ring and pinion (RC)??? when they go to 38 in.rubber. Earl
Kip[UT]
08-04-2003 12:22:48
 Re: Re: help wd to FAST in reply to EarlS., 08-03-2003 12:35:28
I am building a WC puller w/ a "highcrop" rearend
This is the same 6:1 gear as the RC but much stronger. I don't know if there is an equivalent rear end for a WD or WD45, but would think that one out of a cane or highcrop would be geared lower. Standard WC is geared 4:1.
Earl S.
08-04-2003 14:10:45
 Re: Re: Re: help wd to FAST in reply to Kip[UT], 08-04-2003 12:22:48
Kip, Thanks for the info .I will put that in my AC file.Where do you find the used parts?? (Earl In Illinois)
ChadS
08-04-2003 15:29:57
 Re: Re: Re: Re: help wd to FAST in reply to Earl S., 08-04-2003 14:10:45
There is an Allis Chalmers salvage yard in Bourbon,Indiana, His name is Norm Steinman. Has alot of RC,WC,WD,WD45etc parts for sale. Chads
Earl S.
08-04-2003 20:01:03
 Re: Re: Re: Re: Re: help wd to FAST in reply to ChadS, 08-04-2003 15:29:57
Thanks ChadS. I will put that in my AC. file Earl S.
