gasket got a leak in between carb and intake on wd
Andrew
08-03-2003 18:13:59
hi in my previous post about the wd going only 70 ft well i might have found the problem the gasket is out in between the carb and manifold how much does that affect my power
kjm
08-03-2003 21:34:28
 Re: gasket got a leak in between carb and intake o in reply to Andrew, 08-03-2003 18:13:59
If you have a leak it will run lean and could run hot.kjm
TimC
08-03-2003 20:57:32
If it is sucking air it will affect alot.
FB
08-03-2003 18:56:57
A few saturdays a go we made a last minute carb swap and didn't even put a gasket between the carb and manifold, i don't think it hurt our power much at all
Andrew
08-03-2003 20:58:06
 Re: Re: gasket got a leak in between carb and inta in reply to FB, 08-03-2003 18:56:57
at least there wasnt a hole leaking air out in between the carb and intake u had preety even surfaces i bet
Bobcat
08-03-2003 21:09:23
 Re: Re: Re: gasket got a leak in between carb and in reply to Andrew, 08-03-2003 20:58:06
If your air filter isn't very restrictive and the throttle plate is wide open there will not be a very high vacuum at the point were the gasket is. But with the throttle closed it could cause hard starting and idle quality issues. I'm not saying you can have vacuum leaks. But, it probably didn't cause as much of a H.P. problem as you would think.
Jerry
08-04-2003 04:33:56
 Re: Re: Re: Re: gasket got a leak in between carb in reply to Bobcat, 08-03-2003 21:09:23
Excessive wear in the casting were the throttle shaft rotates can also cause poor idling and make it hard to adjust the carb.
