wd rear end
bruce
08-10-2003 09:05:49
I was told that a wd 45 diesel ring and pinion would gear down a wd. Is this correct? And how much of a differance will it make? Does anyone know whare i can find a set for my tractor. I have a gleaner motor in my wd and can't get power to the ground with my small tires.
Charlie
08-11-2003 20:48:56
 Re: wd rear end in reply to bruce, 08-10-2003 09:05:49
If you can't get the power to the ground now, why do you want a lower final drive ratio?
bruce
08-13-2003 19:54:00
 Re: Re: wd rear end in reply to Charlie, 08-11-2003 20:48:56
Charlie i run 16.9 26" tires fron a E gleaner combine. With these tires i have to much ground speed an not enough traction. I need a larger tire for traction and a lower gear so i dont lose all my power. 12x26" tires are stock for the tractor thay spin like a fan! Thay dont hook up at all. bruce
Matt
08-13-2003 18:48:27
So he can run bigger tires.
Earl S.
08-10-2003 10:30:49
Look on the post for 8-3-03 (Help WD. Too Fast) They covered this. Earl
