Hey FB!!
ChadS
08-14-2003 18:53:30
I posted the results of the M I was telling you about. One person does not agree with me as usual, But, like I said, I was not going to lie about the HP numbers. Check it out. See what you think. Thanks ChadS
FB
08-16-2003 15:12:39
 Re: Hey FB!! in reply to ChadS, 08-14-2003 18:53:30
haha i saw that....how many cubes did u have in that thing???? it was just stock stroke and 4 and a quarter bore????have they pulled it yet...it seems to me that all this compression would have some side effect...but by the way ur H's do i am apperantly wrong....do they lug well....wat was the set up on this 1...LP head????4020 LP pistons??i like to know these things so when we go to upgrade ours in the future we will have ideas...ALSO u make your own bushings right?? how much would 4 of those cost for an M rod with a 450 piston...and what do u think the pwer increse with those r????? now u have some work to do answer all these ?'s let alone defending yourself on here
ChadS
08-17-2003 16:56:19
 Re: Re: Hey FB!! in reply to FB, 08-16-2003 15:12:39
297ci, I belive. Stock stroke. 8060 head, ported polished big valves. I am not for sure what kind of pistons they were. The head gasket,governor spring, tuned the carb. this combo alone made the hp increase. 9 time out of 10 the carb is not set up properly. The right carb setup will help the lugging power. Some light clearence work may be possible if you have high dome pistons. If you use the thin head gasket, Remove the studs, clean the surfaces well, and set the head on the block with a few studs in and tighten the head a little bit, turn over engine to see if the pistons slap the head. BE CAREFULL!! Damage could result if the clearence is not there. I make the bushings but I would need your rods, or I have a set, to do the work. If you like, I will put together a price list for the parts I mentioned before. Later, ChadS
