Stuck valve on a 37 Jd A
Brad G
08-20-2003 11:52:38
We have a 37 Jd A that has been setting for about 3 years and has a stuck valve if we can get it started will the stuck valve loosen up and work again???
Chads
08-20-2003 12:33:09
 Re: Stuck valve on a 37 Jd A in reply to Brad G, 08-20-2003 11:52:38
Warning!! dont start engine yet, you better pull off the valve cover and remover the rocker arm assembly. find the problem valve, try and free it up by working it back and forth. If you start that A with the valve stuck open you could hurt the cam, lifter, and push rod. Maybe after it frees up, put some marvel mysery oil in the gas for a while to help clean the valve up Hope this helps Chads
