twisted bolt on 35 A
Brad G
08-23-2003 08:26:35
Im totaly taking my tractor appart for restoration and i was taking the top side bolts off on the radiator and the threads ar in the steal not just a nut and i twisted a bolt off and ther is no head to get ahold of what do i do???
Will i have to heat and drill it out or what is the salution??
FB
08-23-2003 19:34:38
 Re: twisted bolt on 35 A in reply to Brad G, 08-23-2003 08:26:35
we drilled them out as big as possible, then used an easy out
a puller
08-23-2003 11:57:41
you may be able to weld a nut to it and heat it and try to twist it out
