valve setting
bigreddm
08-31-2003 17:53:30
what's the best valve setting for a M?
ChadS
08-31-2003 18:01:07
 Re: valve setting in reply to bigreddm, 08-31-2003 17:53:30
.017 hot. I have used a compression guage when I set valve lash. Makes a world of difference when you use a compression guage to check and adjust valve lash, you can check your work. Hope this helps, ChadS
bigreddm
08-31-2003 18:10:49
 Re: Re: valve setting in reply to ChadS, 08-31-2003 18:01:07
saw your name on other subjects. what kind of governer springs do you have?
ChadS
08-31-2003 18:19:06
 Re: Re: Re: valve setting in reply to bigreddm, 08-31-2003 18:10:49
I have a spring that increases throttle responce by 200% It also allows you to run up to 2800rpm max. You can set it up for any rpm range you like, It makes 3 more hp just by installing this spring. Email me at hpuller@hotmail.com for more info. ChadS
bigreddm
08-31-2003 18:21:24
 Re: Re: Re: Re: valve setting in reply to ChadS, 08-31-2003 18:19:06
i tried your e-mail but i can't get it sent for some reason. any other way to contact?
ChadS
08-31-2003 18:30:24
 Re: Re: Re: Re: Re: valve setting in reply to bigreddm, 08-31-2003 18:21:24
574-893-7437 Indiana time. You can reach me about any time, through the week, I have a shop here and I seem to spend more time there than I do at home sometimes, Ha HA!! My other email address is hpuller20001@yahoo.com as well. Chads
bigreddm
08-31-2003 18:33:25
 Re: Re: Re: Re: Re: Re: valve setting in reply to ChadS, 08-31-2003 18:30:24
thanks
