ChadS
09-02-2003 17:14:24
Re: Need 5 more HP in reply to BUDD, 09-01-2003 16:37:29
The fuel you are running is making as much power to it's potential. Change fuels again, and use the dyno to tune in the carb. You will have to rejet the carb to match your engines potential power. A better fuel with the proper carb modifications, and dyno tunning it will get you the extra power you are looking for. You may look at the tires as well. A better set of tires will hook it up better and watch your weight in the class you pull in, in percentage pulling, the tractor weight is the changing denominator when figuring your percent. Let me give you an example, Our clubs' percentage formula is 83Xinches + 3260, divided by the tractor weight. And that is the percentage you pulled. A lighter tractor, with the proper set up, will beat a heavier tractor that pulls it farther down the track, in a percentage pull. Look at where the heavy tractors are stopping on the track, see what they weigh, and weight your tractor lighter, A lighter tractor does not have to pull the sled as far to build percent,as the heavy tractors in the class have to take it down town to have a good percent. Just figure different weights with the formula and watch the percentages go up as the tractors get lighter. Horsepower may not be the answer sometimes, a good stratagy, could get you that first place over DCTOM. HA HA, Hope this helps a bit. ChadS
