88 puller
brian
09-02-2003 20:15:00
I have a oliver 88 puller with 3 7/8 bore and 4 7/8 stroke. I would like to put in larger pistons and was wondering how big I can go. This is a gas engine. Thank you for any info Brian
OLIVER PULLER
09-04-2003 06:11:17
 Re: 88 puller in reply to brian, 09-02-2003 20:15:00
STOCK SLEEVES UP TO 4 INCH OR CUSTOM SLEEVES UP TO 4.5
Farmall Daddy
09-06-2003 17:49:48
 Re: Re: 88 puller in reply to OLIVER PULLER, 09-04-2003 06:11:17
I have an 88 too, and it only has the 3 3/4's in it. You can put the 3 7/8's-4 inch piston in it with out boring the motor? Also, are they a wet or dry sleeve? Thanks!!
