Off to Roann,In
ChadS
09-06-2003 07:45:34
Gone to Roann,In, for a tractor pull finally got the Z MM running good, Hope it does well today. Good luck to all who are pulling this weekend, be safe, and croos that full pull line!!! ChadS
Farmall Daddy
09-06-2003 17:36:46
 Re: Off to Roann,In in reply to ChadS, 09-06-2003 07:45:34
Have you done anything to your Moline? With the Molines having a good stroke length, should pull rather good. Good luck!! By the way, September 14th, Laotto IN is having a pull. Exibitions are welcome as well too!
ChadS
09-07-2003 08:06:04
 Re: Re: Off to Roann,In in reply to Farmall Daddy, 09-06-2003 17:36:46
It is stock. I have built the carburator to run a good fuel. I reset the valve lash, and used a compression guage, to check the cyl pressure, after I set the valves. I put on a set of 16.9X34,(was not worth a sh!t) and 750lbs on the rear axle. and 6 Ih wheel weights, (3 on a side) and run a 13 inch from center of rear axle, 20 high. It pulled good, made 1 full pull. I was happy with it. Did I mention it was a deadweight pull? ChadS
Farmall Daddy
09-07-2003 15:08:13
 Re: Re: Re: Off to Roann,In in reply to ChadS, 09-07-2003 08:06:04
Sounds like a h*** of a puller!! Do you need wheelie bars for such a pull? Also, do you put you H or any other tractor in pulls like that? Keep up the good pullin though!
Chads
09-08-2003 07:40:36
 Re: Re: Re: Re: Off to Roann,In in reply to Farmall Daddy, 09-07-2003 15:08:13
I was impressed by the power this little MM has. It has more power and torque than a 350 IH. I have pulled my 50 H before, I have done well with it but never won with it. I also have a 58 JD 730 gas. That we pull in the heavyweight class. It weighs in at 9500lbs, with new firestone 15.5X38 (duels) Been doing well with this tractor as well, At Roann, the boat was stuck in one spot, for over an hour, over 10, 8500-9450lb tractors could not shake it loose. Until the our 730. We broke it loose, and made a full pull with it. We pull a 3 man rotation, (3 drivers to a tractor) My mother, even pulls this JD, she loves this type of pulling, Has been pullin, along with my father, since the early 70's She is tough. Our next pull is at North Manchester, IN, this weekend on sat. Yes, you do need wheelie bars, seen too many close calls Chads
