JD 4010 HP Questions???
6 Cylinder Desi
09-11-2003 11:09:37
Tossing around the possibility of pulling a 4010 desiel, and was wondering what kind of horsepower is possible out of it with up grades performance wise in the fuel pump and injectors. Tractor would be used for tractor pulling only, and does not have a turbo. Also how much would an addition of a turbo help horsepower wise. Any help and suggestions would be appreciated.
fritz
09-14-2003 06:54:39
 Re: JD 4010 HP Questions??? in reply to 6 Cylinder Desiel, 09-11-2003 11:09:37
Interested in big cube gas 200+hp email THANKS
Jason
09-11-2003 14:08:31
I know of a NA 4010 that is making 180hp, turbo it and you can double that number it all depends how much $$$$$$$ you want to spend.
6 Cylinder Diesel
09-11-2003 19:09:03
 Re: Re: JD 4010 HP Questions??? in reply to Jason, 09-11-2003 14:08:31
What all was done to obtain the 180hp NA 4010, I assume it was a diesel? And what was done to double the HP with the turbo? Thanks in advance!
