Turbo on M
C.S.
09-03-2001 17:30:42
Can a turbo be put on a super M farmall?If so give me some ideas? Thanks C.S.
1206SWMO
09-04-2001 19:54:37
 Re: turbo on M in reply to C.S., 09-03-2001 17:30:42
Back 20-30 years ago there used to be several M Farmalls here in Missouri that pulled the light Super Stock class.They were turboed with big 4bbl Holley's feeding them and probably turned over 4000rpms.Probably made 300-400 horses.Now it takes 1500-2000 horses to pull light SS.The tractor to beat is Brent Long from Aldrich,MO.Pulls a 686 IH alky burner with 400+ cubes turning 7500rpms with a DOHC aluminum head and one huge turbo.This tractor can turn those 30.5's pretty hard and rarely ever gets beat.
T.P.
09-04-2001 19:17:45
This is somewhat off the subject but an old boy in our area had an F-20 with a turbo on it. As I recall the whistle was off a d-21 AC. He had a Carter 4V feeding it. One other interesting point is that he had a mechanical fuel pump driven off the mag drive. This was back in the early/mid 70's.
T.P.
09-04-2001 19:17:30
Rich
09-03-2001 19:20:31
I have seen and pulled against a gas farmall with a turbo it wasn't that impressive but it could have been the builders fault,maybe that setup works for others,He appeared to have a stock looking updraft carb on it seems like some custom manifolds and a downdraft system would be the ticket.There are some stroked M's that pull in my area and are some good tough competition,hope somone can help you out. Rich B
