Picture Of The Squealer JD 4055 Alky Burner
1206SWMO
09-17-2003 20:02:08
Here is a picture of the Squealer 4055 JD 6000 lb SS pulling tractor owned by the Meeses from Oblong,Ill.I took this picture last Fri eve at Macon,MO.
Its powered by a JD OHC 505 cube alky Brent Long built engine with 3 turbos.This tractor turns 7000 rpms and never runs out of revs.I love seeing this tractor pull.
I saw it pull twice this year.At Troy,MO it put 40 ft over 2nd place and at Macon,MO it again put over 40 ft on 2nd place.Darrel Meese is a fantastic driver.
Due to rule changes it has about been outlawed from pulling as no one can beat it.It was the 6000 SS ATPA champ in 2001.
ATPA rule bender
09-18-2003 21:57:48
 Re: Picture Of The Squealer JD 4055 Alky Burner in reply to 1206SWMO, 09-17-2003 20:02:08
I guess it runs good they are running a overhead cam engine. some how got it grandfathered in to be legal? everyone else has to run push rod engines in the light weight SS class to be legal..... .sounds fair? huh.....
1206SWMO
09-19-2003 19:11:18
 Re: Re: Picture Of The Squealer JD 4055 Alky Burne in reply to ATPA rule bender, 09-18-2003 21:57:48
Its no longer ATPA legal unless they pull 6000 Unlimited SS.This class is seldom offered.
ChadS
09-18-2003 08:38:05
I seen this tractor pull at GOshen Indiana 2 years ago. MAN WILL THAT THING RUN!! Glad to see the green out do the reds!! ChadS
