WD45 stroked crank
Bignbad
09-23-2003 18:57:14
Does anyone know how much you can stroke a wd45 without notching the block? Another one, how much compression can the stock rods take? Thank for any help.
dan
09-24-2003 23:29:00
 Re: WD45 stroked crank in reply to Bignbad, 09-23-2003 18:57:14
460 may work but not long we have 2 one at 425 and another at 450.
bignbad
10-01-2003 18:47:54
 Re: Re: WD45 stroked crank in reply to dan , 09-24-2003 23:29:00
I am looking at 6" stroke, 4.625 bore for 403" 11-1 compression and a good ported head and 2.02 and 1.96 valves, crane cam. AM I on the right track? Alunium front and rear wheels. please help with any AC help you can. Thank you.
blow-by
09-24-2003 15:52:05
Sorry guys', but I thought this would be a good place for my question. I got a old farmall I pull, but a couple weeks ago I was at a pull in michigan, and got talking to a allis engine builder who had a vicious unstyled wc. He said it was 460cuin, he thought it was probaly one the bigger ones in the country. Curious as to how big they are getting these buggers out to? Thanks!!
arky
09-24-2003 19:23:30
 Re: Re: WD45 stroked crank in reply to blow-by, 09-24-2003 15:52:05
An engine builder told me that around that cuin. is about all they will go.
TimC
09-24-2003 06:39:35
6.125 will have windows in the block. I saw this same motor run 275 psi on welded rods for about 5 pulls then boom.
Allis Puller
09-24-2003 03:59:40
I've never went with out cutting the block but another guy told me its 4.750 max. As far as compression I once had 350 lbs of comp. and it was'nt good, it beat the he%* out of my bearings and made a lot of noise. I personally recommend around 200 lbs. Some may say different.
