M govenor tweaking
bindernut
09-23-2003 22:43:34
Hey gang, how can I tweak the govenor on my M to get more RPMs? Thanks
Binernut
POWERTOTHEPULLER
09-24-2003 11:38:14
 Re: M govenor tweaking in reply to bindernut, 09-23-2003 22:43:34
Just replace it with a ROCKET GOV.,it's far better than stock ever was and you will get a Much Much improved responce as well.
Mez25
09-24-2003 11:05:13
You can also just take the governor cover off and remove the spring.....wrap some thin, pliable wire around the spring so that it won't expand....then put the spring back into the governor.....it makes a tremendous difference.
Sleddog
09-24-2003 09:15:31
Change the spring to a cot spring from your local hardware store.
